aiden hallam
- Aug 18, 2002
- 8
- 0
can you help, why do i have to use nitrogen in thr rear shock, what would happen if you just used air while down at the gas station, the same as for your tyres. cheers aiden
Originally posted by Robcolo
...Most air from compressors is pretty dry. The process of compressing it removes most all of the moisture [like wringing out a towel] and most compressors have a centrifugal separator to remove the rest.
GO ahead and air it up ! Those small 12v compressors pass the moisture right on through so maybe wait for a low humidity day.
Originally posted by Jaybird
Houndog, that's quite an expensive way to run pneumatic tools. Also, those racers can use air with the same results as the nitrogen fill IF it is filtered properly.
Originally posted by canyncarvr
I'll stick with nitrogen....although I doubt the bladder cares whether it has a 40 micron something in it or not.......
Badgerman, Air does not permeate the rubber of the tire any more than nitrogen will, the use of nitrogen in tires is so the moisture issue is non-existant.
