PGHRam
62
Hey guys,
I just put the bike back together. I had everything torn apart to do some maintenance. I had the rear brake assembly off. Everything from the reservoir to the caliper. Now when I put it back together, I have no rear brakes at all.
Also, my front brakes work, but are soft. I filled up both reservoirs with fluid.
What do I need to check?
You most likely inverted the reservoirs and got some air in the lines. As stated bleed them out and be patient.
FRESH VIDEO
