Hi there - I'm fettling my aircooled 87 KDX/ 86 KX hybrid a bit more and was after some advice.
The bike makes ok bottom end (a bit weak) then pulls hard in the midrange, then shuts off early without any over rev. It kind of dies out at around 7000 rpm and slows down a bit. Top end doesn't sound great anyway - fluffy, hollow, sort of 4 stroking when you push it hard.
So I'm trying to work out where the problem might lie - which is hard on a bike with so many cross matched parts.
Carb - have an aftermarket 35mm Air Striker but with KDX jetting - all seems ok. Jetted on rich side for WOF running.
Pipe - KDX FMF Gold series with 1.5 cm cut off stinger and has an FMF short KDX silencer - would shortening stinger take away top end?
Ignition - the spark is weak - barely shows up in daylight. On a new plug it starts and runs fine. Hard to start bike once it has been run. Could poor quality spark affect power at top end?
Thanks for any thoughts...
