jaguar
I just got a used Ohlins shock from a '95 KTM 250 and it is in good condition but even with the compression setting at maximum "hard" it still bottoms on jumps. It isn't that the spring is too soft because I put the spring from my old shock on it which is even a little too stiff for my weight. So I'd like to take it apart and replace the oil but I am not sure about how to let the gas out. There is a screw with a nut around it on the reservoir. Any ideas?
Also what weight oil should go in it? I'm thinking about putting in slightly heavier oil to give it more damping.
thanks
thanks
