bbbom
- Aug 13, 1999
- 2,092
- 0
This is from the discussion forums of the Pacific NW 4 Wheel Drive Association. (The counties mentioned are in Oregon but it could happen anywhere.) Don't know for certain that it is factual but, doesn't hurt to be aware of your surroundings.
Motorized Recreation
This is IMPORTANT: Information from the BLM on a pipe bomb that was found at a gate. We have gotten more details. It was an 8-inch long, 2-inch diameter heavy-schedule PVC pipe. It was attached to a Swanson gate in Douglas County. When the bombsquad sprayed it with a water canon, it exploded. It had a mercury switch inside that detonated with movement.
In addition, a small, gunpowder-filled bomb with a fuse was found in Clackamas County. It was made out of PVC also, with two caps threaded onto a double-ended female connector.
If you see something that doesn't look right, leave it alone. Nothing more than terrorism being used to push a very radical agenda.
Don't become avictim. Be alert. Pass on to your riding buddies
