Also converts to 700ccnovadirt said::cool: .7 litres is 700ml
I put in almost 800ml in my 220, I like to see it high in the sight glass.
I know, just posting so he can use a measuring cupGrunta said:700cc is 700ml
Do not forget what it says, it "says" this for a reason. I never run more than 800cc. If we are going to forget what it says why not just fill it up to the top. There is a specific reason amounts are important and there is a certian range of the high and low side of the amount you use that are acceptable. :bang:Braahp said:Forget what it says.....use a quart.
Kwakasaki said:Do not forget what it says, it "says" this for a reason. I never run more than 800cc. If we are going to forget what it says why not just fill it up to the top. There is a specific reason amounts are important and there is a certian range of the high and low side of the amount you use that are acceptable. :bang:
Braahp said:It is widely known and recommended to just use a full quart. It quietens the tranny down.
