KX Insane CY
7
I have a pro circuit works pipe for my kx 250 and it seams to have alot of carbon buildup in the head of the pipe is there any way to clean the carbon out of the pipe. Does anyone know of a product that will work for this. The previous owner of the bike must have been 90 years old to have the kind of buildup the pipe has in it. Any help on this would be apreciated thanks. :think:
Glitch
630
I read somewhere, like DirtRider mag, that to clean the carbon build up in your pipe. Put it in a vise and torch the area of the pipe where the build up is until it is red hot, then let it cool and dump the carbon out which flaked off. You might have to tap it with a hammer or something to get the flakes to fall off, maybe spray it with the hose?
bad ant
15
my 93 KX250 has a leaking right side crankshaft seal and has also been running too rich. When I took the pipe off to pop out a dent in it we noticed that a thick layer of wet black buildup was in the expansion chamber and was burning off with the heat of the gas welder. Thinking we were on to a good thing we systematically managed to burn off quite a lot of it. :)
KX Insane CY
7
Thank you all for the ideas I will first try the oven cleaner and then blast it with a hot water pressure washer. If that dont do it I will grab the fire wrench thanks again.
David Trustrum
1,396
It will smoke like heck & make you sick if you do it indoors. The neighbours will call 911 outdoors.
If it is real bad there may be some places like radiator repairers or engine reconditioners who could dip it in cleaner. If it wasn’t so bad you might do it with a torch at night.
But I didn’t tell you that.
David Trustrum
1,396
Yeah I’ve tried that & the hard carbon doesn’t seem to get infiltrated by it.
Watch out for putting combustibles inside the pipe if you re then intending to hit it with flame as you can imagine the explosive consequences given the right air fuel mixture. If you can’t then think harder. :ugg:
jmics19067
2,097
I have used a small sand blaster with walnut shells succesfully I also used carberator cleaner and a small handfull of walnut shells capped the ends and then clamped the pipe in a paint shaker. But unfortunately I dont think these things are usually available to the average joe. If anyone reading this posts has those means try it you just might like it!!!!!
KX Insane CY
7
I got it cleaned out last night with the fire wrench I had no oven cleaner it sure did smoke but not to worry about the neighbors their burn barrel puts off more smoke than a coal power plant!! Not to many neigbors where I live Im in the woods they dont even complain about the sound feels good to run around in a truck with a 440 mopar and open headers and not get a ticket hehe. Thanks for all the replies. :cool:
