rgs
12
Looking for more bot :silly: tom and mid range from my SX125 , currently 100% standard , would upping the rear to 52 teeth be enough or can anyone recommend a pipe/silencer which would change the power band to boost low - mid range.
Grateful for ANY advice..... :thumb:
ktmdad
314
If you use a shorter silencer you will increase the bottom to mid response. Not sure if any of the aftermarket ones work on the stock pipe.
scott8671
30
I had an FMF fatty and 52 teeth rear sprocket on my 2000 125. That thing pulled like a tractor. With 52 teeth you lose a bit of top end though. You might want to try the sprocket first, but the fatty pipe definately gives it more low end.
