Hi! I'm rebuilding the top end of one of my snowmobile racing engines. I figured that I'd ask here, as the depth of technical knowledge seems better here than on my snowmobile forums. . .
Two cylinder, two stroke, water cooled. 72mm bores. 8200 rpm. Always warmed up slowly and completely before runs. New Wiseco pistons and rings (Swain PC9 coating on skirts - first time), sleeved cylinders are to be honed by one of the big shops, to specs determined by me. I run very lean (oxygen sensor), mostly full throttle, and lots of oil in the pre-mix. A history of scuffing/melting pistons (less now that I am controlling fuel better), poor cooling design. . .
The manual calls for a piston ring gap from 15 to 25 thousandths, which seems high to me. I plan to use oversize rings and grind/hone them to the desired gap.
Piston skirt clearance is 6 to 7 thousandths in the book. Pistons are forged, and the factory clearance may have been determined with cast pistons.
I have software that lets me use the coefficient of expansion to determine hot clearances from cold, piston and cylinder growth being measured by me in a commercial oven to check these values. I am smart enough to play with the numbers to see clearances when one part is hot and the other is cold. . .
So. Top ring (2 rings) to be nearly closed when hot? With just 2-4 thousandths beyond minimum (hot rings cold cylinder) for safety? Bottom with a bit closer to spec gap, say 6-8 thousandths? How much slop should the piston have in the cylinder? I am guessing 4 thousandths.
I hear top rings should be tight, but never butt. Bottom rings a bit more open. My fear of piston clearance is scraping off oil, don't want to depend on that skirt coating. . .
This engine will only run in a break-in event and then national championships, about 10 minutes a year. . . < g >
Thanks!
Thanks!
