Guys,
I've noticed a recurring problem trying to start my '00 KDX 200 when cold...it's a complete pain in the butt! I've tried just getting on and kicking it over, and I've tried the "slowly kick it over till you get compression". Either way it takes forever to start.
I'll kick and kick and kick with absolutely no effect (choke is on, no hit at all with choke off). After a bunch of kicking it'll fire and then die right away. Couple more kicks, and it'll fire, run a little longer, then die again. Few more kicks, fire, run a little longer, and die again. Repeat as necessary. Eventually it'll fire strong enough that it'll keep running. Revs spike, then drop down to the (kinda high) idle I've got it set at.
Once the bike is warm, it starts like a dream. 1 kick (or sometimes even just a 1/2 kick!) is all that's needed to start it up. When it starts it's a bit boggy until I get it on the pipe real good. That cleans it out (usually done within 50 feet of it firing), and it runs great at that point.
I'm running MOTUL oil @ 50:1 and pump gas. FWIW, I get some leaking/dripping out of the carb overflow tubes. This can happen both when the bike is running, and when it's off. Usually tapping on the carb will stop the flow. Are my starting problems in line with a float/needle that needs to be adjusted? Any other ideas?
As I've mentioned, once the bike is warmed up it runs great and is an absolute dream to start. But I'm beginning to dread those cold starts...
Brandon
Brandon
