Are we talking a "real" truck you drive, or an RC truck? Do you know what type of class/level of truck you want to build? What type of resources are you looking to spend on the truck? Depending on the class of vehicle will directly affect the cost. I have worked on Late Model stock cars and would bet that the cost of a truck wouldn't be far behind. I'd expect to see dollars in the range of $40K-$60K for something you can compete with.
Am I way off base or was that the info you were looking for?
Sounds like you might just want to go get a lift kit for it and some big tires and wheels. If you are really ambitious go for a suspension lift kit. Put a nice steering wheel on it and you'll be good to go. :)
You'd be better off using an old 2wd Ford pick-up. In Hunky's book Monkeybutt he touched on some of the ins and outs of bulding a pre-runner type truck. The old Fords are desirable because you can get 12" of travel out of the twin I beam front end relatively cheaply. Plus the twin I beam front end is stonger than the conventional short arm/long arm set up on the Chevys.
