rmc_olderthandirt said:Sleeving is what you do when you need to bore out the cylinder but it has already been bored out as far as it will go.
Boring is what you do to the cylinder when it has been scored (scratched) to the point that a simple honing isn't sufficient.
If the cylinder is supposed to be plated then you need to have the cylinder replated after you bore it. I don't have any experience with sleeving, but I would expect the process would be sleeve, then bore, then plate.
Rod
