490Dave
316
I got a new wiseco piston kit for my KX450, the instructions simply say "arrow must point toward exaust side of cylinder"
This seems a little vague to me, do i install the piston with the arrow on the intake side of the engine pointing to the exaust side, or does the arrow point to the exaust side of the piston or what??? please help!
P.S. What ever happened to the arrow simply pointing to the front of the engine?
IndyMX
Crash Test Dummy
5,548
Amo, IN
Seems pretty clear to me. Put the piston in the cylinder with the arrow pointing toward the exhaust port. Since the exhaust port is on the front of the engine, point it that way..
I don't know what you mean by "do i install the piston with the arrow on the intake side of the engine pointing to the exaust side" unless you have an arrow on the piston pointing toward the center of the piston, which I doubt.
Seems to me that you are trying to make this more difficult than it really is.
Even without the arrow if you look at the piston crown and the valve cutouts, the orientation should be obvious.
490Dave
316
The arrow does point toward the center of the piston! i guess thats whats hanging me up here.
"Even without the arrow if you look at the piston crown and the valve cutouts, the orientation should be obvious."
Sorry! its just not that clear to me that there's any difference!
Thanks for replying
IndyMX
Crash Test Dummy
5,548
Amo, IN
Thanks for replying
Post a picture.
490Dave
316
IndyMX said:
Post a picture.
I'll try
got it!
I've measured the valve reliefs and the intake side is only slightly larger than the exaust. My 47yr old eyes aren't what they used to be......... :(
I guess i just needed somebody to gently whack me on the head.
Thanks again!
490Dave
316
Dylan19302 said:
If the arrow says to point forward point it forward.
it doesn't say point forward......
im not dumb, i just wanted to make sure it was correct before i put it all back together!
thanks anyway!
Dylan19302
111
is the bike a 2 or 4 stroke. if its 2 then there will be a solid side of the side of the piston and that side goes to the exhaust. And you said that the arrow points to the exhause so thats what i would do.
What you should do, is stop posting. :bang:
oldguy
Always Broken
If you would take the time to read
As Rich said maybe you should take up reading more and posting less
490Dave
316
Im happy to say the rebuild went fairly smooth (except for the whole piston thing) and have 2+ hours of track and trail on the bike and everything seems good. The only difference i can tell is there's a little more snap in the power on accelleration.
A couple of things to note:
1)besure to keep the rag stuffed into the case until you're ready to seat the head, make sure alignment pins stay put.
2)besure to snug the valve cover bolts all the way down or else the seal leaks
3)The front chain guide notch needs to go below the head gasket, it's difficult to keep it in place while setting the head, be patient and get some help.
Thanks!
