I put the smaller grip on the throttle side and the other on the other side.I put hair spray on them and the one on the none throttle side came off with a little pull but how do I take the the one on the other side off?WD40?
WD will work, but you'll have to clean it out real good before installing again. If you have compressed air and an air gun, use that to blow it off. Just insert the nozzle between the bar and the grip (if you can get it in there) and blow it off.
