Hi there!
How do you polish small scratches out of fork legs? I was told to use first 600, then 800 and finally 1000 sand tape with a little bit of fork oil. I did try it with a fork leg on a lathe at nearly 1200 rpm but I must say that the surface is a bit rougher than on the places where I did nothing. Another hint was to use scotch brite for the finish, until now I didn't try it. So it is up to you...how do you do it?
