Jasle
- Nov 27, 2001
- 1,358
- 0
Can anyone explain the theory of the spacers that you add under your cylinder on a two stroke? I guess it changes your port timing but how does this affect the power band.
I am specifically asking because my pistion has been back-ordered for a few months while the dealer looks for a new vendor. The replacment which is made for a newer bike is the same dimensions except the wrist pins makes the pistion stick out of the top of the cylinder. The newer cylinder has more area added to the top of the cylinder. I could easily make a base plate spacer the .080 I need to push the cylinder up to accomodate the pistion but how will this affect me? Also I could make the same spacer for the top. The seal is o-ring so I could machine a spacer with an o-ring groove. The top pistion ring is below the top of the cylinder so just the top portion of the piston would protrude in to the fabricated spacer. The cylinder is nik-a-sil coated so I guess I would have to coat the spacer too? The spacer on top of the cylinder doesn't really sound like the way to go but it seems like it would be the easiest way to match the stock bikes new style head.
I know its starting to sound cheasy but I need to make this work until the right pistion comes out unless i want to drop $450 for a new cylinder.
Thanks Jason
Thanks Jason
