can anyone help me in the setup of the power valve
no top end power at the moment
are there marks
when is the main valve open up or down
all help would be appreciated
none of the valves are stuck
the bike is a 1990 mx250 ktm
ive been told that when the main valve is down the sub valves should be shut
as the main valve moves upwards the sub valves open
there is a spring on the side with the actuator rod
i dont know how this should go
