I just completed installation of the 38kg springs that I had purchased from Fredette Racing. Based upon the many threads I have read in this forum, 10mm seems to the going "preload" setting, so I followed suite. After all was completed , I removed the bike from the stand and sat upon it, there was a significiant amount of "sag" difference between the stockers and the replacements. When I state significiant, I mean the bellows folded up quite abit. Did not take for a test ride, just sat upon it and "bounced" around and the front end seems extemely "soft". Has anyone else recently performed the above and ended up with the initial response?
Not to leave any details out, I did change the fluid out completely (turning forks upside down, ,moving fork rod in & outwards many times). Replaced fluid as per the service manual instructions, 100 mm from the top. As I was in no hurry and being my first at this, I took lots of time and double checked myself throughout the entire process.
Fredette did include some intructions that stated to set the preload same as "stock" springs. But all I have read states the stockers have too much preload, so I opted for the 10mm. Is this were I have errored ?
I did note during the process of measuring for the correct preload that there was 4mm lenght difference in the new springs. Therfore I cut each spacer accordingly. Is this common.
Thanks in advance for your opinions.
