my pw-50 has almost no power i checked the compression it had 60 psi is this good or bad i also was wondering if i could find a pic on how the reeds go together?
You don't really need a pic, they are pretty straighforward. When you pull the reed block out, just get a good look. Unless you are looking at AMA racing, I recommend the Boyeson dual stage reeds. Someone else can chime in on the psi, I don't have my manual handy.
