My little ones PW 50 won't go past idle unles you put the kill switch between the off and run mode. It idles in the start mode, then you move it to run and turn the throttle and it still only idles. If you move the switch between run and off it will rev up normally.
I'm thinking the switch is bad. The last time he rode it, it kept cutting off and I thought it was the spark plug wire as I seemed to move it and it would start and run again. I don't think that has anything to do with it though now.
Anybody had to replace this piece, wonder if you have to replace the whole throttle piece or just the switch?
Thanks,
Jim
Thanks,
Jim
