I bought my son a used PW80 last year and have been doing some mods to it this spring to give it a little more go. So far I have put a fatty pipe and PC2 arrester on it, raised the needle clip 1 notch (as well as cleaned out all the crap in the carb), air filter and filtered vents in the box, 13 tooth front sprocket, and some boyeson power reeds.
The little bike goes MUCH better now and my son is really excited about it all. I must admit, I have become a little addicted to working on it cause it is so small and simple. With someone to help I can throw the whole bike up on the bench, work on it, then take it down and go annoy the neighbors trying it out. It used to be in pretty hard shape when I first bought it. It still needs to have the top end gone over but I'm not sure if I want to go that far with a PW80. I can hear piston slap. Does anyone know if that would make a big difference or can I just let that go?
Anyway, my real question is about the tires. The rear tire needs to be replaced. The stock one is a Cheng Shin 3.00-12 and I was looking around to see what other choices I had and don't see any other 3.00-12 size tires from other manufactures. There is however 80/100-12 size tires from several other makers like Michelin's Starcross. Is this a comparable tire size that I can use? I would appreciate any input.
