trakkerman
- Nov 12, 2001
- 258
- 0
I got a shock rebuild and new shock spring (5.5) and new fork springs (4.8) through your associate John Curea at East Coast Racing. I just installed the fork springs and noted they were about 1-1/2" - 2" longer than stock. I also found that the stock plastic bushing/washer that is used on each end of the stock spring could not be re-used with the new springs which I discarded.
My questions are: The springs rub the inside of the slider most likely because of the extra length. Is this a problem?
Also, should I try to fashion a new plastic bushing?
I appreciate the quick turn around on the rebuild and parts!
Randy Brown
Randy Brown
