The "optimal" base valve area has to depend on what peak velocity is desired by the fork.
Evaluate the conditions - SX, MX, desert, woods, rocks;
Rider level - play rider, novice, intermediate, expert, pro;
Fork design - CV or no CV, bleeds or bypass, charged system, downstream restrictions outside the cylinder...
:eek:
Optimum base valve almost begins to sound like optimum spring stiffness. :confused:
These considerations and the midvalves physical limitations to flow are critical in deciding the base valve's port size. The base valve must prevent the mid-valve from cavitating. The base valve and restrictions in series provide the maximum pressure in the system. The midvalve is in parallel and cannot have a pressure differential above the basevalve limits, determined by the factors listed above. There are ratios of port size between the base and midvalve which need to be adhered to in accordance with the relative flows between the two described in this thread above (3:1 to 5:1 volume ratio) in order to maintain precise valve shim control of the damping. Oversize the basevalve and lose valving control, undersize and limit peak compression speed. Generalizations are hard to come by.
Don't you wish these things could be a little simpler? :)
James
[This message has been edited by James Dean (edited 04-19-2001).]
