bdf112
15
I know this might sound dumb I Am new to the motocross seen and i would like to ask what does clicks mean is it half a turn or whole turn or what?
rickyd
Hot Sauce
Oct 28, 2001
3,447
WHen you adjust the clickers, you will hear/feel a clicking noise.. SO say if you turn the clickers all the way in, then you go 3 clicks out, you can hear/feel the clicks.. Hope this helps you out,
Rick
KTM-Lew
428
On adjusters that click it is usually at 1/4 turn intervals. In your case you will have to screw the adjuster all the way in GENTLY and count the turns out slowly and gently. So 6 full turns would be 24 "clicks". Your bike probably won't go more than 3 full turns (12 "clicks") or so. The little bikes don't have as much adjustment as the full sized bikes.
