I just installed my .40 FRP fork springs on my '03 200. I measured and cut the PVC to be 10mm longer than the space between the top of the springs and the bottom of the cap when screwed all the way down (with spacers installed) as I have read to do on here. My question is, when I cut my spacers I noticed that they were a little shorter than the stock metal spacers that were origionally in the forks, is this normal? I can't tell you an exact measurement but I would guess they were about 20~30mm shorter than stock. Also, the FRP springs were very close to the origional spring length. I just wanted to check and make sure I didn't do anything wrong.
