dirtbikr99
- Nov 21, 2002
- 180
- 0
I have a 1999 cr250. (old but I love it) Currently Its stock bore 66.4 I've had a ported, and cut the head to raise the compression a little. I love the motor right now. However, I've come across and amazing deal on a stroked crank 74mm.
1. Is it possible to just put the stroked crank in (check to make sure it clears the cases of course) and put a 2mm spacer plate under the cylinder? Will this have any effect on the porting, timing or compression?
2. What would be the final displacement with a stock bore and a 74 mm crank?
Thank you in advance to whoever can answer these questions for me!
