Kawadougie
77
I remember reading on one of the posts here that a lot of exhaust spooge is unburned fuel and I feel that the quality of gasoline has dropped dramatically in the last few years. I've not been overly impressed with the power output from my 2002 KDX200. It has the usual upgrades of an FMF pipe and spark arrestor and Boyesen reeds. Stock carb with a 45 pilot, needle in middle position and a 150 main jet. I've been using Chevron Premium with Maxima Castor 927 at 40:1. It ran OK but not great. Mind you, it gets down the trail just fine and never fouled a single plug.
I drained the tank, increased the main jet to a 155 and mixed up a batch with Trick Racing Fuel and was greatly impressed. It flat hauls ass now. The first three gears it will wheelie as long as I want and it rockets out of the corners. :yeehaw:
I used to get some spooge coming out the exhaust and landing on the rear fender but today the silencer and fender look clean. It's not that I was racing today either, I was hanging arrows for an enduro. I'm still going to send my cylinder off to Eric Gorr for a porting job but this was an amazing transformation.
23jayhawk
675
KD, how is the fuel you're buying sold? The specs on the leaded Trick look promising, if you could get it in sealed 5 gallon cans. After reading extensively on the value of race fuel, I tried to find either Phillips B35 or VP C-12 around St. Louis. Good luck - no one stocks either fuel, but I can have it special ordered and shipped for about $65 to $70 per 5 gallon can.
Consider yourself fortunate if you have a local retailer who stocks and sells enough volume to amortize the hazmat and shipping costs to a more reasonable level.
Kawadougie
77
Several local dealers here in the Sacramento Califoirnai area sell it in five gallon sealed containers. I paid $25.00 for the gas and $10.00 refundable deposit for the can. I intend to run nothing else in my bike from now on. :)
Jim Crenca
509
IMO, running race fuel in a reasonably stock (original compression & porting) only gives you consistancy from batch to batch that you won't get at the pump. I have found that crisp jetting is where the power really is, especialy response. I've experimented with C-12 and believe that my bike snaps a little better although overall max HP feels about the same. I have spent zillions of hours jetting for temp, altitude, humidity, & fuel brand and the main gain with C-12 is consistent response (assuming that it's fresh fuel stored in a sealed metal container, etc.
In the future, you may want to make one change at a time (like just a main jet or fuel change with same jetting) to realy know what caused what. I think that you made an overly rich bike closer to correct jetting and the fuel may have had very little to do with it. BTW, what did plug look like after WOT chop?
Search in Advanced Tech under "fuel" or "gas" and you will be amazed at the amount of info.
Kawadougie
77
Hi Jim,
I've been riding dirtbikes for almost forty years now and I know it made one heck of a difference. I had leaned the main down to a 150 with pump gas to get rid of most of the spooge that was coating my silencer and rear fender. A plug check at Prairie City OHV turned out a nice medium brown on the center electrode. Not overly rich. I increased the main to a 155 and it ran great with the race gas. Haven't had a chance to check the plug yet but the bike pulls harder than it ever did. The silencer and the fender are clean now which would seem to indicate complete combustion.
jaguar
1,508
82
South America
from lukesracing.com
"# Fuels- Some common misconceptions about race fuel are: 1. It burns hotter and can cause your motor to overheat 2. It will give your motor more power. 1. Race fuel is a high Octane fuel. Octane is a reference number that tells how much heat the fuel will withstand before detonating without a spark. Octane itself is a fuel similar to gasoline, it was given a rating of 100 to use a reference point to compare to gasoline. The amount of heat produced by a fuel is measured in B.T.U.'s. All gasoline's produce about the same amount of heat so race fuel will not cause your motor to overheat, in fact in most cases it will run cooler (race gas has additives that increase the cooling effect it has when it evaporates, like the cooling effect rubbing alcohol has on your skin). If high octane fuel was more likely to do engine damage they wouldn't use it in aircraft engines 2. Every engine requires a slightly different minimum octane to operate properly. If your motor requires 91 octane and your using 93 octane then it probably wont gain much from 108 or 114 octane race fuel. Most race fuels will require rejetting because the fuel carries more oxygen than pump gas, without rejetting it's possible that your engine will run leaner and produce less power. So why pay more for race gas? High octane race gas allows you to build an engine with higher compression, more spark advance or leaner fuel mixture, without detonating the fuel. The power advantages of race fuel come mostly from these changes. The higher oxygen content means you will run bigger carb jets to get the correct fuel mixture. Your engine will burn more fuel because it has more oxygen available to burn the fuel. Octane is just one of many specifications of race fuel. The specs of race fuel are measured and adjusted to the legal limits according to racing organizations. Every gallon is check and will be the same every time you buy fuel (if the fuel is fresh). Pump gas can vary greatly from one week to the next or from one station to another, and they only check samples of pump gas from thousands of gallons they produce. Different additives are added to pump gas according to the time of year and location where it will be used. In winter they add more alcohol to help remove moisture and they use additives to make the gas evaporate better at low temperatures ("vapor temperature"). Gas that will be used in very hot climates is given additives to lower "Vapor Pressure" to prevent "vapor lock". This is great for your car (especially fuel injected cars that measure and adjust fuel mixture electronically) but for a race bike it can alter your carb jetting from one tank of gas to another. The main thing to remember is to check carb jetting if you run race fuel, also remember if your going to go back to pump gas you may have to switch the jets back. In most cases stock 2 strokes run well on premium pump gas with the proper carb jetting and will gain little from race gas. Unless your building an all out "race only" motor I suggest using premium pump gas or mixing one gallon of race gas to 3 or 4 gallons of pump gas. Whichever you choose you should use it consistently."
Kawadougie
77
Hi Jaguar,
Way to much for me to read. ;-) Although, from the report, if you run race fuel, jetting richer and running cleaner should net more horsepower!!! Works for me! :yeehaw: :yeehaw: :yeehaw:
Jim Crenca
509
That's like saying you've added weight to the bike to slow it down because it has bad brakes. If the bike is jetted rich, re-jet it (IMO).
jaguar
1,508
82
South America
You've got a point there Jim but the article did also say that the race fuel had more of a cooling effect which would be advantageous over normal gas. But he should probably jet it leaner and then try it out with normal gas and then make the decision whether or not the race gas is worth the extra expense.
23jayhawk
675
I know this may be heretical, but I really don't need any more power. What I WOULD like is all the throttle response & jetting consistency available. I would even trade a couple HP for instantaneous response that's linear to throttle opening, since I can use that everywhere. Most of the trails I ride I'm lucky to get 2nd gear wound out, and rarely 3rd.
Braahp
641
If it works for you thats what matters. But if you don't have the compression that requires higher octane fuels then you are actually wasting tons of money and its losing hp. A KDX only needs 90 octane.
DJM67
57
......... pump fuel here in Australia has been blamed for causing siezures during motoX races. It is pretty poor quality stuff (Some European manufacturers even have to re-jet their bikes at the factory before they ship them here just to run properly on our fuel).
"Aviation style" racing fuels have been banned in racing so riders have been forced to use fairly low grade pump fuel, even some premium pump fuels will not pass the regulations.
canyncarvr
4,005
Jag: Thanks for the credited info! I even read it...and yanno what? It's all right!! (there! THAT should make everyone feel better!)
The whole idea of more 'octane' being an absolute good thing is of course bogus. It can be just as easily a BAD thing as a GOOD thing. Actually, more likely the former than the latter.
re: vapor pressure
Every spring you can see STACKS of cars on the side of the road due to this exact thing. The 'winter gas' (modified to vaporize 'better') hasn't been changed yet and on a warm day the road that runs from the valley floor (1300') to the siskiyou pass (4000') at miles of 6% grade is littered with vehicles that just don't run on vapor lock! Imagine that!!
Anyway, thanks for the info!!! lukesracing has some good stuff!!
BTW...re: 'plug check........... a nice medium brown on the center electrode'
That (color) is an indication of plug temperature mostly, so doesn't directly say anything about A/F mixture (if that's what was meant). Air/fuel mixture is 'read' way down the insulator where it meets the plug shell.
Still, if the plug heat range is correct for the bike, plug temperature being effected by A/F mixture the color thing is not completely at odds with the conclusion.
...but it doesn't directly show A/F mixture. Not to mention which/how many of the 1/2 dozen carb circuits were being used at the time......
Kawadougie
77
I actually meant I was reading the insulator color. I've been reading plugs a long time and apparently Eric Gorr agrees with me. http://www.eric-gorr.com/techarticles/sparkplugs.html
Over the years I've run both pump gas and race gas in various motorcycles and the most I ever gained from running race gas or octane booster was a crisper throttle response or lack of pinging in my YZ490. ;-) Imagine my surprise when my KDX gained a lot of horsepower on race gas despite the fact that it was jetted pretty close to optimum. (in my jaded opinion) Point is that no one has yet explained why I experienced a fairly major power gain by simply changing fuels. All anyone has really said is that my jetting was poor or that it just isn't possible. I'm not convinced yet and despite the increased cost will continue to enjoy the horsepower.
Jim Crenca
509
If it works don't fight it.
You might want to read the fuel article written by Rich that is also on Eric's site.
I think the reason that no one has explained why a low compression bike makes more horsepower on race gas is that there is no documentable reason based in physics that can support it.
Crisper response yes, but not more HP (IMO).
canyncarvr
4,005
You bet! And I run a couple º retarded because I like the result! Albeit a different result than what it's supposed to be, by 'rule'...but yanno what?
I really don't care! ;)
You might want to read it again :scream: It's loaded with incorrect info like :
and this "gem"
The BS was getting so deep I had to stand on a chair to keep my shoes clean :scream:
