KaTooMer
- Jul 28, 1999
- 435
- 0
I just killed the afternoon trying (unsuccessfully) to set the race say on my '02 KTM 300MXC. It's not rocket science, but I'm thoroughly confused. The rear spring is a PDS6 (260mm), which is the next-to-softest 260mm spring, according to the manual. I weigh about 170-175 pounds with all my gear on.
The smallest level of race sag I can get is 115mm, which is with the preload ring turned down so that there's about an inch of threads showing (probably more than recommended). At that amount of preload, it gets very hard to turn the preload ring. I assumed that the spring is too soft, so I swapped the shock from my '99 300EXC and tried it in the '02. The '99 uses a PDS2 spring, which is a 250mm spring that is stiffer than the PDS6. Stiffer spring should mean less sag, right? Apparently not, because the PDS2 had MORE sag on the '02 bike (about 125mm). The PDS2 works perfectly for me on the '99, and is set with 100mm race sag.
So I'm confused...the PDS6 is not going to work, nor is the PDS2. Seems very odd that the PDS2 works fine with the '99 but not with the '02. The bikes aren't that much different. I've not heard of anyone having problems with sag on the '02's. Any ideas?
Thanks.
Thanks.
