Moo
52
I have had my computer for a while now, and I think it's time to re-install (or remove) Windows 98.How exactly should I go about re-installing? What files will I need to back up? I have a CD-RW drive, so backup shouldn't be too big of a problem. Thannks.
spanky250
Mod Ban
Dec 10, 2000
1,490
Are you just trying to freshen things up a little, eliminate some small glitches? If so, just re-install windows on top of itself to restore the system and operating files. All you have to do is insert the CD in your drive, go to Run, and type D:/setup to start the process, then follow the prompts. Afterwards, run defrag and regclean, and you are all set.
If you are using a new operating system now and want to get rid of win98, just go to add/remove programs and delete win 98. You won't lose anything, because all your data is duplicated in the folders of the new operating system.
