1985 KDX 200
Rear shock has kind of a dead spot when fully extended. I assume this because it is low on oil. So I took it out to rebuild it. Well after punching that cap of the top of the shock body I realized it was so corroded that I probably shouldn't pull the piston out. Anyways, what I would like to know is there a way to change or add oil through the resevoir hose? Maybe submerge the hoses and pump the shock? Thanks
