Its time for a top end, as it's harder starting when hot, I can jump start it in 1st gear with a half worn rear tire, where before it wouldn't with a brand new tire, and it does pull at low RPMs as good as it did. It's a stock 94' kdx200 except it has a reed spacer and FFW. I don't think the top ends ever been done, but I might be wrong. The crank bearings and seals where done when I rebuilt the tranny 1.5 years ago.
My question is, should I split the cases and rebuild the crank w/new rod and top end ($800), rebuild just the top end ($300), or could it do with just new rings ($100)? My mechanic recommended the full deal because of the bike's age, being worried about the lower rod bearing. If the full package is required, I'll do it, but if not necessary I'd rather spend 100 or 300 compared to 800.
Thanks for your opinions,
Tamean
Tamean
