mideastrider
- Jul 8, 2006
- 827
- 1
It’s time to rebuild the head on my crf450, I already have the parts, new valves, springs, retainers, seals etc. all OEM. Now I see a kibblewhite intake set for the Honda includes everything.Debating if I should use instead of the oem. It’s been talked about on here a lot and appears to be the way to go. I went to kibblewhite website just to read up on it. I am confused on whether to lap/seat or not. In the FAQ section it states the valves are designed to be faced. It all so says “All KPMI Black Diamond Stainless Steel Valves are impregnated by a special German process to .002" deep with a .0002" surface build-up to improve wear properties and reduce friction.” Seems like facing the valves would begin to remove this special process. My question is it ok to just change the intakes and keep the oem exhaust valves? I will have the seats cut/resurfaced will it be necessary lap the intakes?
