ecy063
112
I have read several threads that say a worn out reed valve can mimic an over rich fuel mix condition. In theory I would think the reverse would be true. If a reed valve was failing it would allow to much combustion gasses into the intake tract and therefore lean out the mixture by lowering vacuum over the carb jets. Scavenging in the exhaust tract could also be adversly effected causing more spooge to be sucked back into the cylinder. Fouled plugs? Maybe I am spending to much time thinking and not enough time riding. :yikes:
ecy063
112
I can't wait until my new rad valve gets here to find out if I stop getting spooge on my plug When the motor is cold. How do you like your '94. Mine flat rips but always had cold start problems.
