hey, I am having a problem with the way my bike runs. It seems to bog down and not hit the powerband in 1st and sometimes 2nd gear. It is also spitting out oil from the silencer.
It seems to run much better if I hold in the clutch and rev it out a couple of times, so I am assuming that I am getting too much fuel. I played around with the air screw a little, but it didn't really help. So I am assuming that I am having a jetting problem. From the reading that I have done it looks like it could be the pilot jet, but is probably the jet needle. It looks like I need to go to a smaller diameter needle or change teh clip position to go to a "leaner" length.
Does this sound right? How do I adjust the needle?
thanks for the help,
Rick
Rick
