Associated drive tools for above. Recommend you get the sliding t-handle for each size.
Torque wrenches, 3/8" and 1/2" drive at a minimum. 1/4" optional.
Set of metric allen wrenches. Full set, plus a smaller set of t-handle allen wrenches.
Full set of screw drivers including torx
Pliers, diagonal cutters, needle nose pliers, large adjustable wrench, safety wire pliers
Chain breaker, exhaust spring puller (make it out of a coat hanger).
Above is the minimum in my view. More specialized tools required if you are going to rebuild your own engine and suspension.
Others will think of the things I left out. Look in the Sears tool catalog to find most of the above. Safety wire pliers can be found at Harbor Freight or at your local MC shop. The chain breaker tool should be at the local shop as well.
