you should follow the directions on the reed package,it should tell you that if you do not use the factory reed stops ,you should lean the main jet 1-2 sizes at a time
simple mistake,and if you have black drool,thats oil not burning completly-try klotz ,it burns cleaner than a lot of oils out there,repack the silencer-its probably full of the gooy oil as well
check the crank oil and see if it is burning it
put the stock pilot back in,check the plug after changing oils--keep us posted
