2strokes4life
- Apr 1, 2009
- 39
- 0
Alright guys I know what you're thinking. Oh great can't he read the jetting link. This problem is driving me nuts. Here is what happens. I have a 2002 RM 125. I bought it with a messed up top end. It has a new cylinder, wiseco piston kit, new fatty pipe, and new FMF silencer. The bike idles like a champ. When you put it in gear and take off, it bogs big time off idle. If you grab a handful of throttle off idle, it will bog so bad that if you keep it wide open it will die. If you ease past this point, it does hesitate a little before the powerband but then responds pretty well in the zone. I tried buying the JD jet kit and this didn't solve the problem. I called them and they sent me a larger pilot jet. I've tried different main jets, needles and needle positions. It acts like crud in the carb. I've had the carb off and blew carb cleaner through it, but have never soaked it. I'm always a little leary of the soaking chemical. I'm not sure what to remove when soaking one. I have been troubleshooting this since the fall. I gave up over the winter and tried again today with the larger pilot from JD. No luck! I'm ready to turn this over to a mechanic unless you guys have any last ditch ideas. Thanks in advance for any ideas.
