Animostical
4
Well I just got a RM125 dirt bike and there are some problems with it. I got if for 700. Well I can start it up when its cold in like 2-3 kicks. But when its warmed up my leg is about to fall off. And it idles really high when the idle is really low. Let me know if you have a solution. Or if you need anymore information on this problem. Really appreciate it.
Evan
BigRedAF
739
From the minimal info that you provided it sounds like your using the choke to get it started causing the high idle.
I'm guessing that a carb clean is in order and pay special attention to the pilot jet.
AwfulSmokey
55
Definitely. Take the bowl off and spray the crap out of the carb or soak if necessary. Take the jets out and clean the orifices.
Animostical
4
Well like I said. If you need more info let me know. And I was also told that I need my top end done. Can this be a problem?
Ron2stroke1
41
Yea its def a top end, i had the same problem with my 125. I wouldent order the top end kit until you take the cylinder off and check it for damage.
