What should the sag be set for on the front forks ??. I am riding Enduros and at present the fork is to stiff and is bouncing off everything. I believe if I reduce the preload it will help ??
do you measure the sag the same as the shock? Whats the best measuring points? What is the total spacer length for a 470mm spring (to make it 10mm preload or 40mm of race sag)?
Sorry to jack your thread, but I thought you could benifit from this info. too.
