it should be 100mm of sag for any weight. i have a 220 ,and weigh about the same as you, and my suspension is stock and it had the right sag for me so it should be fine for you. but if u wanna know more the december issue of motocross action magazine it has a good section on how to set the sag, what it should be at,etc.
Measure the distance from the axle to a point on the rear fender with the suspension unloaded (on a stand). Now measure the distance again with you and all riding gear on the bike so that the suspension compresses; bounce up and down a few times before you measure, to make sure the suspension is completly setteled. The difference between the 2 should be between 95-105mm...105 is usually for sand.
as long as you measure from the same spot both times it doesnt matter where you measure from. then you subtract the distance with you on the bike from the distance when the bike was on the stand.
O.k. now I'm really gonna test your patience and memory. How about a clicker starter point for a 5 7" 165 # woods rider. Almost bounced over my handle bars today! Next time I will stand when I go over the small knoll in 5th. Or w/ new settings can I stay seated?
They are all set to std. settings:
rebound - 14
compression - 16
To change the measurement you would move the lock ring that holds tension on the spring. Probably loosen the top and tighten the bottom. ( these two rings are at the top of the spring) After you get the correct measurement tighten the top ring down. Clicker adjustment will vary slightly on terrain.
Is the 100mm applicable for both front and rear? I come from a roadracing background, where front and rear sags are *not* the same. 100mm front and 100mm rear? Thanks!
Question? Do I set the sag at 100mm or set the distance from the top shock bolt center to the 2nd lock ring, as per the owners manuel? RUTS <>< (there is a big difference in the two)
Im 5'8 and can hardly touch the ground on my 2003 kdx200 when i adjust the spring on the uni-track it becomes very bouncy should i adjust the damper also to stiffen the shock ? Im new to uni-tracks and im not sure on where to start , But i'm have a hard time holding the bike up around corners and thru trails because i cant touch the ground.
thanks
Try some searches on the matter. There are posts on this site with links to numerous suspension sites explaining the whole process...how, when, why, etc. etc. Some of the older listed links may have changed. You might try motolinks.com (valid URL not listed for a reason) to find all sorts of links to services, parts, information and such.
Briefly, a couple of things I don't see here that are important.
re: Where you measure from/to.
It makes a big difference. It's clear that you have to measure @ 90º to the suspension action, right? Don't see that noted. Does that need explanation?
re: Screwdriver and hammer.
If you wanna. A lot less damage (read: none) if you loosen the lockring with a drift (screwdriver if you must), then adjust the spring length by TURNING the spring. Easy to do with bare hands. Suspension unloaded of course. ;) Helps if the spring is wetted with some soapy water. Having the frame extension rod out makes it easier, but isn't necessary.
re: sword30
Sorry...the lack of any punctuation in your first 'sentence' makes it impossible to understand. You can 'hardly touch the ground when you adjust the spring..'?...or when you '..adjust the spring it becomes bouncy..'?
No way your shock spring should be 'bouncy' at all, period, never. IF your suspension indeed 'bounces', you need to adjust either/both the compression (top) or rebound (bottom). Compression needs to be SOFT enough (clicks out) to absorb impacts without jacking your arse, HARD enough (clicks in) to take as large an impact as you're going to give it. Rebound needs to be FAST enough (clicks out) to be ready for the next impact (not 'pack'), SLOW enough (clicks in) to keep the wheel on the ground during the rebound process.
The forks are compression only (for most of us dollar impaired, don't-got-rebound-modification-$$ conventional fork slobs). First, have the correct spring, oil level, preload for your application. Then, adjust the compression so it will be soft enough to not jar you to death and feel every pebble but NOT bottom (well, maybe seldom) on the roughest stuff you ride on.
If you want your bike lower, check out kouba links. They make pull rods of a longer design that will lower your kdx by up to over 2 inches. Yes, the front does need to 'fit' this drop. Read the FAQ info. You may need a stronger shock spring in some cases. The longer rods increase the leverage on the shock. This is more often a good thing than bad. Devol makes a set, too. They are adjustable, but only to: 1. Normal, 2. One position longer, 3. One shorter. In the 'longer' position, your seat height will drop about 3/8".
re: jfrancis.. 'top shock bolt center to the 2nd lock ring'
It's as beefking said. Nothing is measured on the shock.
re: wallasaki 'over the bars'
Maybe that was due to your fork springs being 'phoof' (fluff..soft)? If the back end kicks THAT bad, you might try a few more clicks OUT on the shock compression. ...probably your front end, though.
It could all come from too much gas at the wrong time, too! If you're powering all the way over, you'll pile drive the front end into the ground.
