Ok I know someone has had this problem before, The upper shroud bolt won't come out of my gas tank on my KX. Do you think if I cut it off I could get it out somehow by holding the insert some way? Or can I cut it off and then pull the insert out and put one of those things that you rivet in with new threads? If the thing will even come out. Thank you
