Look where the valve is to fill with nitrogen. It goes there. If you want to see a diagram go to www.buykawasaki.com and click on the tab near the center top of the screen labeled vehicle information. Then click on the pull down menu item view parts diagram. From there, follow the choices until you get to a 1998 KDX200. The right side menu on this page has a choice for shock absorber. This site really helps identify almost any part on any kawasaki made. Good Luck! JerryLarry K. said:I took the spring off the shock a month ago (to have it re-valved) and for the life of me can not figure out where part# 92033A ring-snap shock absorber part goes. This is on a 98 KDX any help would be appreciated.
