First off this is my first post on here and you will be seeing alot of me since I have just started motocross
So hi everyone.
So bear with me if I ask the most basic of questions, because at the moment I really don't know that much about them
( But I am learning! :yeehaw: )
right where to start....
Yesterday I picked up my bike, Yamaha YZ 250 98' model.
In great condition, engine, plastics, etc.
Started it up which took only 2 kicks, engine sounded mint, rev'ed it about 8-9 times abserloutly fine. Plus checked cables fine, breaks in A1, sprokets fine and so on.
Took it home started it up only took 1 kick this time, turned it off using the emergency stop.
Now this is the wierd bit ......
10 mins later tryed to start it, no luck, tryed again, no luck, tryed at least 10-15 times gave up because my ankle was hurting like a bitch.
Left it for another 15 mins again no luck, I checked the gears, was in neutral, and I even pulled the toke lever up to help, also made sure the switch was also on, AGAIN NO LUCK. Checked in the tank there was hardly any petrol at all, could that be it? Or even if you have a tiny amount, should it still start up fine?
I was also thinking could it be the spark plug, it might be dirty, but I will admit, I don't know how to remove the spark plug yet ! :bang:
But I was showed by a friend and I think its basically in the middle of the bike, with a adjustable screw to tighten and loosen, am I correct?
So that made me wonder for awhile, but then later that night .... tryed to start it, yay ! Fired up second time. Stopped it, then done it again with 2 kicks, well pleased then turned it off and put it to bed for the night :boss:
So basically whats going on? I mean could it be not enough petrol in the tank? Or has all the oil been used up? Could it be that the spark plug is dirty? Could it be something else at all?!
The seller told me the engine is in A1 condition and I do believe him, not only that but the kick start is brand new aswell so it could'nt be that (or is it?)
Any advice would be much apresheated :cool:
Also I dropped the bike (Well it is bloody heavy!, I know ....)
And the front brake lever snapped clean off :|
Can a clutch lever be used as a front break lever? If so then thats good.
Few questions:
Should I use this spray lube called FX-7 (I THINK) or oil to be used on my chain? WD-40?
Do I need to use 2 different oils for my bike? 2 stroke for mixing with petrol, and normal engine oil for engine?
Where else should I lube/oil?
What is tranny oil?
Any info would be great.
So hi everyone.
Few questions:
What is tranny oil?
