1998 RM125. Clutch doesn't disengage all the way. Tried filing out the notches in the basket already, but doesn't seem to help. When the bike is cold, shifting into first is realllllly jerky. After it warms up, it's not so bad, but it still drags real bad. If I have to restart it, if it's in gear and the lever is pulled in, when I kick it, the bike pulls forward and it's hard to start. Idling is another problem. When in neautral, it idles fine, but in gear with the cluthlever pulled in, it won't. Is this just the way things are, or is something funky with my clutch? Should I try replacing the clutch springs? Does my cable need replacement? Lube job?
Also, on the kickstarter, I have to replace the oil seal. Can I just unscrew the kickstarter from the outside and replace it, or will I have to break down the bottom end to get inside and do it?
Thanks much,
Brian.
Thanks much,
Brian.
