stripped counter sunk screw removal..
The Redrider
238
32
Here is one for you mechanics. I have a 89 250R and I accidently stripped a phillips head screw in the top master cylinder cover. Handle bar located. I tried an ease out bit but the tip snapped off. Its badly stripped, whats my next step? :$
First try pulling it with a good VESSEL impact driver. I've gotten around a lot of ham-fisted rider stripped screws (many of my own doing) over the last 45 years with one.
If that's not available use a fine tip center punch to mark the center as close as possible and drill it with the tiniest drill you can. Once you have a clean hole increase the drill size a little at a time till you weaken the body of the screw and can peal it out.
If you are very good with a TIG welder, just drop a bead on the top of the screw and let the metal contraction shrink the screw. Done correctly they will usually come out by hand. If the first dab doesn't do it add a bit more till it eases out or you build up enough metal to file a slot in it and unscrew it.
The Redrider
238
32
Thanks Rich, I'll try the center punch and small drill bit first. Fingers crossed, Thank again!
The Redrider
238
32
I wonder why Honda put phillips counter sunk screws in the master cylinder cap? A hex head bolt would work just fine....
It's countersunk to provide a flush surface. Fewer sharp edges to hurt a rider in the those less than perfect moments.
