2wheel-jimbo
- Apr 8, 2004
- 1
- 0
hi, im taking apart my forks on my 2000 yz125. i have the outer tube off the inner tube and the compression cylinder out of the inner tube. my question is, how do you take the crimped ring off the push rod to remove the assembly out of the cylinder? what can i replace that ring with, and where can i get it, or can the ring be reused? and when i have the rod and piston assembly out, how do i remove the nut without wrecking the threads(because of the staking)?
thanks
thanks
