tall seat cover with tall seat foam????????
Can Can Kev
233
okay i searched for a answer and i couldnt find anything so here it goes, do you have to use a taller seat cover when using tall seat foam? or will any standard seat cover work , liek the ones that come with graphic kits, because the ceet seat foam suggests using taller seat covers, im confised!
Reesknight
942
I used the same aftermarket cover that was on mine when i put the tall seat foam in. It was a tight fit but it worked(barely). I'm not sure if some of the cover had been cut off by the previous owner tho.
NEMX305
106
Yes, if you run a tall seat foam, a tall cover is needed. In some cases, if there is enough material left on the cover when it was made, a regular cover works. I just put a tall factory effex foam, and cover on my 04 KX250, and the fit was perfect. Tim
nikki
Moto Junkie
Apr 21, 2000
5,802
Red has the Moose complete tall seat, and he put a standard seat cover on it with no problems. His seat cover is the 2003 Team Subway Honda seat cover and I'm not sure who makes it off hand.
