jaguar
Here's mine:
My shock blew out, and chewed up the teflon seal band around the piston head. Without it there is no rebound or compression control, just all spring. Well, I looked around for something to use and found the teflon/metal band for the fork slider (the upper one) is the same diameter and thickness. It was just about twice the width so I had to cut it through the middle lengthwise to match what I need. Oh, the o-ring that goes below the band was also destroyed so I just used silicone sealant under the metal/teflon band. Put it all together and it works! Not as good as it should but it will get me by until the new band and o-ring arrives.
OK, let's here your story of high tech garage engineering.
