Ok just a little help needed here.
I have a 95 RMX250R
Mods
TwinAir Filter (recently cleaned and properly oiled, no rips or tears, seals well)
No air leaks that I can find in the bike
I have a RB Designs breathed on carb, a PWK38
SJ #50
MJ #175
Needle DEK clip is on the 4th clip from the bottom (I always forget how to read that)
A #7 Slide moded by RB Designs
The air screw (AS) is at 2 1/2 turns out from closed.
Plug is dark brown
I run Hi-octane fuel at 30:1 mix
V-Force Reeds
FMF Pipe with FMF Silencer
The bike runs very well, the power is so smooth of the bottom all the way to the top.
The problem is that I have had to screw the idle adjusting screw in a lot to get it to idle, (not the AS, but the screw thing that actually lifts the slide a bit)
After WOT, with the throttle closed surges along, also when I come to a stop, with the clutch in the bike idles very high for about 25 seconds (I've counted), then it settles down and idles well, in traffic this is a pain.
The gas in new, the oil is good, and the carb vents are clear, and the tank vent is too.
Is this a lean or rich problem?
I'm looking at the pilot ciurcuit here, I'm thinking of changing the SJ to a leaner one, a #48 or #45 as I think it may be rich, due to the color of the plug (dark brown) but I seem to remember that the surging problem, with the throttle closed after WOT is a sign of lean jetting....
Help me out here guys, I have a riders training session (Gymkhana in Japanese) on Saturday and I want/need smooth power.
Cheers!
I have a 95 RMX250R
Mods
SJ #50
MJ #175
Plug is dark brown
V-Force Reeds
Cheers!
