Badgadjit1
235
These Worth it? Revised
is this worth the money. 20 bucks plus 4 dollars shipping
go to e-bay and type this
" Motocross Numbers Pre-Aligned. Not pre-printed. THICK! "
cut and paste it
Pre-Aligned Motocross Race NUMBERS
(Custom set of three includes ALL digits)
* 12mil. High Gloss Vinyl
* Strong Adhesive
* AMA, FIM, and NMA Legal
* Available in Black or White
JST122
645
I responded to another post you had up before called "numbers" I dont know if you looked at that you havent responded at all. Anyway, in my opinion if you were to get these numbers you still would need to purchase the number plate backgrounds before putting them on. Sure you could probably just stick them to the plate but if you do that I think over time the bare plastic plate that is not covered by the sheet over the numbers will begin to discolor and the portion under the clear sticker over the numbers wont. So after purchasing the number plate backgrounds as well you would be up around 50 bucks or so anyway. So in my opinion I would just spend an additional 15 bucks and get the pre-printed backgrounds and numbers like I mentioned in your other post. If your goal is just to save money I can understand that and then I would just go purchase the individual numbers from the bike shop and put them on yourself, they are not hard to align if you take your time. just line them up prior to removing the sticker background and make a small mark to center each number on and you will be fine.
Simulcaster
36
One Industries numbers at the shop are usually arpound 6 bucks a pack for 3 numbers. If you are running 3 numbers this is a better deal than if your runnning 1 digit or 2 digit numbers. Yes they are already aligned for you but is it really that hard to line them up one at at time? If your placing your numbers right on the plastic this is probably the way to go if you're in a hurry. If you spend 20 bucks on the backgrounds then 20 bucks on the numbers plus shipping....... your at the price of a basic set of preprints that will hold up way better than option 1. If they were 5 bucks plus 5 bucks for shipping...that would be a different story. remember in order to go faster you should go slower..... even with your fancy numbers.
